OOMDAS
Makergear M3-ID, T1 (right head) problem w Vs 5.0.1
Heads 1 & 2 (left & right) have been working perfectly with Vs 4 for some time.
Just updated to Vs 5 and was enjoying great results with the left (T0) head.
When attempting to print with the right head (T1), although the print preview shows T1 as the active head, at actual print time T0 tries to print, crashing into T1 and generating cold extrusion errors.
Anyone got any ideas please?
PS already posted on the MG forum on FB - no answers yet.
airscapes
Re: Makergear M3-ID, T1 (right head) problem w Vs 5.0.1
roll back to the working version and wait... .. .. .. .. .. .. .. . .. .. . .. . . .
If you look at the top of the gcode, do you see any T0 or T1 commands? If it looks correct in the S3D preview, I suspect those commands already exist in the gcode.
OOMDAS
Sorry for the delay answering - the forum wasn't advising me of any replies to followed topics due to an incorrect setting, now fixed.
The GCODE starts with...
; G-Code generated by Simplify3D(R) Version 5.0.1
; Feb 14, 2023 at 10:16:50 PM
; Settings Summary
; processName,3D Solutech PETG
; targetModels,2023.02.14.2015 Smaller Shower Squeegee Holder v1
; profileName,MakerGear M3-ID(3)
; profileVersion,2023-01-09 21:04:59
; app,S3D-Software 5.0.0
; technology,fff
; baseProfile,MakerGear M3-ID
; extruder,Right Extruder
; toolheadNumber,1
; nozzleDiameter,0.35000
; extrusionMultiplier,0.90000
; extrusionWidthMode,manual
; extrusionWidth,0.40000
; useRetraction,1
; retractDistance,2.00000
; extraRestartDistance,-0.03000
; retractVerticalLift,0.00000
; retractSpeed,6000.00000
; useCoasting,0
; coastingDistance,0.20000
; useWiping,0
; wipingDistance,5.00000
; speedMaxFlowRate,1000.00000
Skip past all the semi colon comments. You should see commands like G90, M83, etc. Do you see a T0 or T1 in that area?
OOMDAS
Sorry - I'd forgotten that the semi-colon stuff is just comments. I should have known better.
It was supposed to do the bed level checking with T0, then switch to T1 until end of print. T0 should not have been required to warm up at all.
Immediately below all the comments...
G90
M82
M106 S0 P0
M140 S75
M190 S75
M104 S245 T1
M109 S245 T1
M605 S0 ; set x-carriage mode to independent control
T1 ; Switch to right extruder
G28 ; home all axes
G1 X210 Y40 Z0.1 F10000 ; go to wait position
G1 X195 F5000 ; scrape off any ooze from heating
G1 Z7 ; move the bed down to avoid collision
G1 X40 Y6 F10000 ; move toolhead to the unused front edge
G1 Z0.20 F1000 ; move bed to prime start position
G1 X160 E10 F1000 ; prime the nozzle
G1 X170 Z0.05 F5000 ; quick wipe
G1 Z7 Y20 ; move the tool away to start printing
; process 3D Solutech PETG
; layer 1, Z = 0.1350
T1
G92 E0.0000
G1 E-2.0000 F6000
; feature skirt
; tool H0.1350 W0.500
G1 Z0.1350 F1200
G1 X95.785 Y79.522 F18000
G92 E0.0000
G1 E1.9700 F6000
G92 E0.0000
G1 X97.129 Y78.079 E0.0498 F1750
G1 X98.074 Y77.183 E0.0827
G1 X99.213 Y76.222 E0.1203
G1 X100.383 Y75.364 E0.1570
G1 X101.718 Y74.529 E0.1967
G1 X102.937 Y73.894 E0.2315
G1 X104.452 Y73.251 E0.2730
G1 X106.163 Y72.728 E0.3182
G1 X107.296 Y72.488 E0.3475
G1 X108.551 Y72.320 E0.3795
G1 X109.881 Y72.257 E0.4131
G1 X111.501 Y72.324 E0.4540
G1 X112.875 Y72.518 E0.4891
G1 X113.943 Y72.757 E0.5167
G1 X115.550 Y73.252 E0.5592
G1 X116.807 Y73.774 E0.5936
G1 X118.231 Y74.500 E0.6339
G1 X119.644 Y75.384 E0.6760
G1 X120.944 Y76.347 E0.7169
then similar commands for many lines.
I must have something wrong with my settings somewhere as the last few lines contain...
M104 S0 T1 ; turn off right extruder
M104 S0 T0 ; turn off left extruder
M140 S0 ; turn off bed
G1 Z205 Y250 F1000 ; move the bed all the way down and to the front
T0 should have been turned off before T1 started to print.
I don't see any T0 values in the gcode, so it definitely looks like the software is telling the printer to correctly use T1. This might need to be a question for Makergear if the firmware is using the wrong tool when you send a T1 command.
GuyGuy
Hello,
To overcome this situation, I created 3 profiles.
1 for the left extruder (T0)
1 for right extruder (T1)
1 for dual (T0 and T1)
For the management of the filament cooling fans, I manage this with a script (I'm using Klipper)
OOMDAS
S3D-Jason wrote: Thu Feb 23, 2023 1:40 pm I don't see any T0 values in the gcode, so it definitely looks like the software is telling the printer to correctly use T1. This might need to be a question for Makergear if the firmware is using the wrong tool when you send a T1 command.
As I said originally, the same sketch, re sliced in V4 prints perfectly using T1, so I'm not sure that is the answer.
OOMDAS
GuyGuy wrote: Thu Feb 23, 2023 2:57 pm Hello,
So you have the same issue with the same printer?
