studiokite
Re: Custom firmware no longer available in v5, import machine models no longer available.
We are using a custom machine built with industrial automation gear. See the Studio Kite / Cadzilla article on your page.
I use a seperate command for fan on and fan off. Worst case scenario I will just post process it. It is not ideal though.
bcprint3d
S3D-Jason wrote: ↑Tue Jan 24, 2023 1:32 pm What printer are you using? Let us know what commands you need to change and that will make it easier to propose the correct settings.
I am using a E3D tool changer, which requires changing the ALL of the commands listed on the old Firmware Configuration->FFF window. Without the ability to change these settings, S3D v5 will not work for the Duet firmware with multiple extruders.
studiokite
I fixed mine in post processing but I am sure that wont apply to everyone.
I still think it sucks to have to edit the profile to change the machine model.
