S3D-Jason wrote: ↑Mon Feb 20, 2023 10:01 am
Are you using version 5.0.1? The flow rate color range should be determined by the actual flow rates in the gcode file.
yes, I am using version 5.0.1 ...
Have you looked through the preview to see where the red flow rate color regions appear?
there is no red colored region ... all is deep blue as the maximum flow rate is related to > 900 mm^3/s (
https://i.imgur.com/0vf2XkC.jpg). My max. print speed is 175 mm/s which is approx. 15 mm^3/s with a 0.4 mm nozzle.
The flow rate display is not granular enough to review the flow rates used in the print.
