PreppingPenguin
Neptune 4 Pro Print Files
Hello all,
When I was printing from Cura I would get a usable file to load into Neptune 4 Pro and it would print, when I am using Simplify3d and save the file to drive the Neptune 4 Pro is not recognizing the gcode and does not print anything. Is there a setting that I have missed somewhere to make this printer work with this software?
Re: Neptune 4 Pro Print Files
What exact error do you see when you run the file on the printer?
WF55
PreppingPenguin wrote: ↑Sun Oct 08, 2023 7:11 pm Hello all,
I also switched from Cura to S3D. Making the adjustments wasn't easy for me.
This mainly related to adjusting speeds and temperatures. Regardless, the G-Code could always be read by the Neptune 4. The problem shouldn't just be with S3D.
