DaveAhrendt
[SOLVED] Auto configure issues
I see that some people appear to be using the auto configure for quality/material and I assume that it works for them.
I've been trying to set some items but I'm having no luck. Nothing seems to stick.
I wanted to change the first layer height dependent up layer height selected by my quality options, Fast, Normal, Detail. I can add
first layer height percentage as a auto configure option, change my percentage for Detail to 200%. I then update the profile. As long I don't
exit the settings dialog all works OK. If I quit and reenter the dialog the change is gone.
Am I missing how this is supposed to work.
Re: Auto configure issues
I just ran a test here, but it worked fine for me. The steps were:
- Edit Process Settings > ... button > Assign Settings to Categories
- Search for "First Layer Height" (you will find 2 entries, one for relative and one for absolute)
- Assign both of the "First Layer Height" categories to Quality
- Hit Save and Update Profile
After making those changes, I can set a different first layer height for each of my quality levels in the profile.
DaveAhrendt
Thanks. That works. I didn't noticed there were two entries for Height. It may be helpful to know which setting you're changing since you see the same string. It would also be helpful to be able to sort the list.
