ssassen
Monotonic infill sequence?
The 'monotonic infill sequence' is mentioned as a new feature for 5.1. I'm trying to find this setting but have a hard time locating it? Could anyone perhaps point me in the right direction? Thanks!
Re: Monotonic infill sequence?
If you type "monotonic" into the search bar in the top right of the process settings window, it will take you to the new settings. It's on the Infill tab. You just enable that checkbox and then the new feature is enabled.
yoda
Hello, in my 5.1.2. version is missing this settings. At tab INFILL is nothink about it ... how can I use it?
I should be the checkbox at the bottom of the "Solid Layers" section on the Infill tab. It's called "Minimize direction changes (monotonic)"
