CreatorX
Raise 3D printer wifi, USB, ethernet support
Bonjour
My Raise Pro2 printer is not detected with Simplify5 connection Wizard.
USB, ethernet or WIFI doesn't work
Answer from Software technical support :
"Thank you for your request. I would be glad to forward support for the Raise3D WiFi as a feature request to the development team. I am sure they will evaluate this request along with many others for the future releases. "
Seems that Simplify5 does not support Raise3D printers connection :(
Merci
CreatorX
Re: Raise 3D printer wifi, USB, ethernet support
Hello,
Unfortunatly, no change in V5.1 version .... :|
CreatorX
.... no change in V5.1.1 version .... :|
CreatorX
Bonjour,
.... no change in V5.1.2 version .... :|
Anybody have solution ?
Am I the only one with a Raise3D printer ?
The only solution is to install IdeaMaker (Raise3D) software to transfer the code :roll: :cry:
CreatorX
I think that the compatibility of Raise3D printers will never be implemented by simplify3D. :cry: :|
A workaround :
- Create a Gcode file with ideamaker with the same orientation and layer thickness that you used in Simplify3D.
Ideamaker creates a Gcode file and a ".data" file.
- Upload with Ideamaker the gcode file created by simplify with the ".data" file from Ideamaker in the same directory.
You will have on the Raise3D printer the display of the drawing and the printing time.
