GoldMark
Simplify3D crashed (Linux)
Simplify3D 2.2.1
Xubuntu 14.04 LTS 32 Bit
After installation s3D worked fine. Then i would print 3 models at once via USB after 15-20mm skirt printing stopped and system was black (no reaction) and then shut-down. After restart i could not longer print via USB from S3D (Error massage that a connection not possible). Saving the G-Code is possible via Manual Control of S3D. After some reboots i have the same behaviour.
Any hints what to do?
Best Regards
Bernhard
Best Regards
Bernhard
Simplify3D 3.1 Lubuntu 16.04 LTS 364-Bit
Mendel90 Nophead with alu plate and 1mm carbon plate on top. Print only with PLA
habloIngles
Re: Simplify3D crashed (Linux)
What specific connection error are you getting? Also have you tried this?
http://forum.simplify3d.com/viewtopic.p ... 1544#p5852
GoldMark
habloIngles wrote:What specific connection error are you getting? Also have you tried this?
When i am home from office, i will look for it. And try the mentioned solution. I will keep you update.
Best Regards
Bernhard
GoldMark
Thank you! It seems that this was the problem.
Best Regards
Bernhard
GoldMark
I can now confirm, that the hint from habloIngles is the solution for my problem.
Dear developer team,
can you solve this problem?
You only must include at the end of the installation script, a sequence, that the user has an access to all files/devices too and not only the root.
Best Regards
Bernhard
