dsuprina
How to set Communications Timeout in V5
How can I set the Communications Timeout for a specific printer known to Simplify3d V5?
In V4 the input field was found at Tools/Firmware Configuration/Communication/Configuration Timeout. That input appears to have been moved, but its new location, or the the means by which this timeout is set for any given printer, is not apparent.
This is required as long diagonal extrusions can cause a "Response Timeout" error message to be issued.
jgschmidt
Re: How to set Communications Timeout in V5
Hello, has anyone found a solution? I'm experiencing the same thing. I've got a custom Core XY with a large build volume running SmoothieBoard.
