Good evening... So i just sliced at 40mm/s for everything... and 80% of that speed for first layer.
WHen i slice it and look at the color guide, its not even close...
Its showing first layer at like 5mm/s (which after a test print, seems about right)
It shows no more than 20-25mm/s for the rest of the layers. A tiny bit of green (showing around 40mm/s) on some outer layers.
All the settings are showing as I set them. My FF Creator pro has acceleration enabled (not that would matter in the slicer).
any thoughts?
thank you
