Good afternoon internet people.
I just purchased my first FFF printer, a Wanhao duplicator 4S. Initial impressions of the hardware is pretty good. I have run into a couple typical Chinese hardware issues which I'm resolving with the manufacturer, but overall it is pretty good. I am running the latest release of Simplify3D and upgraded my firmware to the latest Sailfish through ReplicatorG 40R30. The prints look very good, most likely due to the seemingly high quality of the S3D code output. One issue I am having which seems to come up on the web frequently without a thorough explanation is how to set Steps Per MM for my Cartesian axis? I have been into the firmware settings within both RepG as well as S3D, and it is clear that this is NOT how you actually change the hard settings of steps per MM within the hardware. I came across some reference to GPX this and .ini that....none of it makes a whole lot of sense, and there doesn't seem to be enough documentation out there to actually self-teach some of these more complicated settings. I require the very best dimensional accuracy possible out of this printer as I'll be using it for prototyping machine/product parts which must precisely mate with each other. It is clear that some tuning is required, but no clear path to accomplish said tuning.
I am currently printing a 25mm cube with all faces coming in at around 24.65-24.7. I have done this same print multiple times with the same result each time. The print material is PLA, and I'm printing on a heated glass bed. Any assistance getting to the information precisely explaining the axis steps calibration process would be greatly appreciated.
SG
