Dual printing requires a purge wall function so that when changing tools, the new tool starts on a purge sacrificial wall before going to the actual print.
Please look at Makerboot for an excellent example.
Wow!JoeJ wrote:You could do this by adding 4 lines to your tool change script. That will make sure that the commands are executed before EVERY tool change, so just tell it to go print a square somewhere and it will prime the nozzle.
I did this with a purge line before.Ola wrote:Wow!JoeJ wrote:You could do this by adding 4 lines to your tool change script. That will make sure that the commands are executed before EVERY tool change, so just tell it to go print a square somewhere and it will prime the nozzle.
Please enlighten me, I do not have any experience with writing G-code.
I assume I go to "Tool change G-code" and insert... what?
If you give me an example, I will figure it out hopefully.
I have a Replicator 2x, with two extruders.
G1 X10 Y-70 F1200 ; Move to the start position of a new line
G1 X50 Y-70 E2 F1200 ; The value of E is changed by Simplify3D, but need to be there to draw a lineCode: Select all
G1 X-10 Y-70 F1200 ; Move to the start position of a new line
G1 X-50 Y-70 E2 F1200 ; The value of E is changed by Simplify3D, but need to be there to draw a line
