Ha, yeah. I was pretty frustrated by that point. I am going to try the tweaked profile.KC_703 wrote:Wow... bitter... you should get a refund.
G21 ; metric values
G90 ; absolute positioning
M82 ; set extruder to absolute mode
M107 ; start with the fan off
G92 E0 ; set extruder position to 0
M140 S[bed0_temperature] ; get bed heating up
G28 ; home all
M109 S140 ; set to cleaning temp for particular filament and wait
G1 Z150 E-30 F75 ; suck up XXmm of filament
M109 S140 ; heat up rest of way
G1 X45 Y174 F11520 ; move behind scraper
;offset for nozzle size different from standard
;G1 Z10+4.45 ; move to 10 + (16 - 12 +.45) mm above Z=0
;G92 Z10 ; set the current position to Z=10
;end nozzle offset
G1 Z0 F1200 ; CRITICAL: set Z to height of top of scraper
G1 X45 Y174 Z-.5 F4000 ; wiping ; plunge into wipe pad
G1 X55 Y172 Z-.5 F4000 ; wiping
G1 X45 Y174 Z0 F4000 ; wiping
G1 X55 Y172 F4000 ; wiping
G1 X45 Y174 F4000 ; wiping
G1 X60 Y174 F4000 ; wiping
G1 X80 Y172 F4000 ; wiping
G1 X90 Y172 F4000 ; wiping
G1 X80 Y174 F4000 ; wiping
G1 X100 Y172 F4000 ; wiping
G1 X110 Y174 F4000 ; wiping
G1 X115 Y172 Z-0.5 F1000 ; wipe slower and bury noz in cleanish area
G1 Z10 ; raise z
G28 X0 Y0 ; home x and y
M109 S140 ; set to probing temp
M204 S300 ; Set probing acceleration
G29 ; Probe
M204 S2000 ; Restore standard acceleration
G1 X5 Y15 Z10 F5000 ; get out the way
G4 S1 ; pause
M400 ; clear buffer
;M140 S[bed0_temperature]; get bed temping up during first layer
M109 S[extruder0_temperature] ; set extruder temp and wait
G4 S15 ; wait for bed to temp up
G1 Z2 E0 F75 ; extrude filament back into nozzle
