For now i try to populate the tips & trick page.
I guess your friend is not telling the truth.habloIngles wrote:Have you tried the zip folder I included above? It's working for my friend who has a Malyan M180acefx wrote:Yesterday , i wrote to s3d support and they gave me that files to, but for now it doesn't work... the extruder doesn't go to the center and doesn't do the wait for heat up and the first "waste" extrude, instead of that it begin to print where it is...
++Added some harware mods
I use gpx [output_filepath] in my scripts tab > post processing command for and it works for me...helmutdz wrote:I guess your friend is not telling the truth.habloIngles wrote:Have you tried the zip folder I included above? It's working for my friend who has a Malyan M180acefx wrote:Yesterday , i wrote to s3d support and they gave me that files to, but for now it doesn't work... the extruder doesn't go to the center and doesn't do the wait for heat up and the first "waste" extrude, instead of that it begin to print where it is...
"additional terminal commands for postprocessing"
Windows :
[install_dir]\gpx [output_filepath]
no matter what one enters here. is only for the post-processing.
and the gpx.ini will not be processed.
Can you post a screenshot of the communication log when s3d is trying to connect to your m180?acefx wrote:Ok after many & many try, i couldn't succeed using s3d... so i stay on makerware 2.40 ( i try to hack the other version ).
I succeed producing some part with this software. The only remaining bug is the Z offset who seems arbitrary don't know if it's software or hardware dependant.
I'm going to make a wiki about that...
If someone succeed using s3d in direct usb print, tell me , if not i will refund my licence ( 2 weeks period )
And my next one will be a makerbot original
