kdpainter
Re: Anyone using Simplify3D with the Luluzbot Mini?
KC_703 wrote:Wow... bitter... you should get a refund.
Ha, yeah. I was pretty frustrated by that point. I am going to try the tweaked profile.
kdpainter
I have tried the revised profile and it worked much better. Thank you!! However, the standard nozzle diameter is 0.5mm and when I tried with with ABS, it started printing when the bed temp was still 60 deg C and ultimately my first print failed. I changed that to heat up to final bed temp right away. I also have put a nozzle that is 4mm longer than the standard one so I have code to compensate for that. Here is my profile. The nozzle offset is commented out. Here is the startup gcode from the profile:
G21                          ; metric values
G90                          ; absolute positioning
M82                          ; set extruder to absolute mode
M107                         ; start with the fan off
G92 E0                       ; set extruder position to 0
M140 S[bed0_temperature]     ; get bed heating up
G28                          ; home all
M109 S140                    ; set to cleaning temp for particular filament and wait
G1 Z150 E-30 F75             ; suck up XXmm of filament
M109 S140                    ; heat up rest of way
G1 X45 Y174 F11520           ; move behind scraper
;offset for nozzle size different from standard
;G1 Z10+4.45 ; move to 10 + (16 - 12 +.45) mm above Z=0
;G92 Z10 ; set the current position to Z=10
;end nozzle offset
G1 Z0  F1200                 ; CRITICAL: set Z to height of top of scraper
G1 X45 Y174 Z-.5 F4000       ; wiping ; plunge into wipe pad
G1 X55 Y172 Z-.5 F4000       ; wiping
G1 X45 Y174 Z0 F4000         ; wiping
G1 X55 Y172 F4000            ; wiping
G1 X45 Y174 F4000            ; wiping
G1 X60 Y174 F4000            ; wiping
G1 X80 Y172 F4000            ; wiping
G1 X90 Y172 F4000            ; wiping
G1 X80 Y174 F4000            ; wiping
G1 X100 Y172 F4000           ; wiping
G1 X110 Y174 F4000           ; wiping
G1 X115 Y172 Z-0.5 F1000     ; wipe slower and bury noz in cleanish area
G1 Z10                       ; raise z
G28 X0 Y0                    ; home x and y
M109 S140                    ; set to probing temp
M204 S300                    ; Set probing acceleration
G29                          ; Probe
M204 S2000                   ; Restore standard acceleration
G1 X5 Y15 Z10 F5000          ; get out the way
G4 S1                        ; pause
M400                         ; clear buffer
;M140 S[bed0_temperature]; get bed temping up during first layer
M109 S[extruder0_temperature]    ; set extruder temp and wait
G4 S15                       ; wait for bed to temp up
G1 Z2 E0 F75                 ; extrude filament back into nozzle
LulzBot_Mini_kdp_no_nozzle_offset.fff
(11.03 KiB) Downloaded 404 times
