SailorCM
Re: Malyan M180 3D Desktop printer ?
Hi! :-)
now i'm also a 3D FreeSculpt EX2/Malyan M180 owner - i've also some issues using the printer:
* Objects are too small - 2mm smaller than designed (different slicer's - same result)
* Octoprint cant communicate with the printer
* x3d-Files created with makerware caused that the printer drives the extruder to too far to front left
* x3d-Files created with makerware seem to incorrectly drive the z-axis (objects have 10% of height as they should have and a lot of filament is swelling on the corners)
the problems are still present - even after upgrading to firmware 7.8
Does anyone has an advice?
Thanks in advance
Benedikt
SockMonkey
SailorCM wrote:Hi! :-)
Thanks in advance
Benedikt
You have to use RepG or a custom gpx.ini with Simplify3D Software as the Maylan M180 printers use a different steps/mm for the Z-axis. Also octoprint, as far as I know, only communicates with printers running RepRap style firmware with ASCII communication, whereas Makerbot and the clones have a different communication protocol, so integration with OctoPrint is not currently a vailable.
khudko83
acefx wrote:Ok forget what i've said :
http://wiki.malyansys.com/wiki.php?id=f ... _procedure
Firmware and update produre are on the wiki page .
Hi! Do you have a malyan M180 profile for S3D?
Can you share it?
There is already a profile for the Malyan M180 available in Simplify3D. Just go to Help > Configuration Assistant, and select that printer from the list ;)
kezg
Hi, So im using S3D v3.0.2 and i cannot get a few things to work such as:
Fan control - No matter what i set it to it always just runs at 100%
Temp - when setting temps for extruders and bed, it never works and i have to manually adjust temps via the controls panel on the printer. I can get one extruder temp to set to what i want, but Never the bed, always goes to 0.
eg: extruder 1 = Extruder T0
extruder 2 = Extruder T1
heat bed = heatbed T0
Only extruders temps work. If i set heatbed T0 value nothing happens.
anyone know what im on about?
works fine for me with the stock profile that's already in S3D
kezg
stock setup not working for me, I can get the right extruder temp correct and sometimes the heatbed, but mostly i have to start a job then set the temp manually from the front panel.
Cannot get fan adjustment to work at all, Should be easy i know how it's supposed to work- it just doesnt do anything.
Anyone have anything to offer?
You might want to try reading this thread: viewtopic.php?f=9&t=4007&p=17468#p17496
kezg
Still cant get it to work. the scripts just seem to mess it up more for me.
GrayCat
Hello from Ukraine!
Has anybody tried the new firmware samples from http://wiki.malyansys.com/doku.php?id=f ... _procedure ? Especially interesting is the "Marlin firmware": does it have any new features compared to stock one (except for the promised "accept plain text GCode") ?
Gray©at.
