LCD
Witbox 2 ... Temperature drops
Hallo. I habe big problems with the g-code generated by simplify and bq Witbox 2. It starts so:
G90
M82
M106 S0
M104 S215 T0
M109 S215 T0
M800 ; firmware starting routine
The firmware starting routine must be at the beginning. Not after setting the extruder temperature, or the temperature drops. This is a serius bug. I'm only able to print, after reordering the g-code or changing the temperature manually
Re: Witbox 2 ... Temperature drops
LCD,
Have you tried using the starting script's temperature variables?
[extruder0_temperature]
[bed0_temperature]
If these are present in the start script, the software shouldn't be adding temperature commands above the start script. Also, I'd suggest unchecking stabilize at startup (In the temperature tab).
more info on the variables can be found here: viewtopic.php?f=8&t=1959
more info on custom starting scripts: https://www.simplify3d.com/support/arti ... #M104-M109
LCD
Hi S3D-Jake, Thank you, this sounds good. I will try it with my next print tomorrow
LCD
Successfully tested. Thanks!
