johnibarresto
which is the best 3d printer available in the market under 1500$?
hi
i am new to 3d printing and can't make my own printer so someone suggested me to go with creality 3d cr 10. my friend told me about it but i can see few reviews here best 3d printers under 1000.
let me know what should i choose! my budget is around 1500-2000$
Mthompson
Re: which is the best 3d printer available in the market under 1500$?
CR10S5
EZABL
6mm Glass
PEI
Solutech PLA 190/60
IC3D ABS 220/100
S3D
Thingiverse
Autodesk products
C_Birch81
Like most things, people have there own needs from a printer. So you need to take into account not just how much you can spend but what do you need the most, eg build size, dual print heads, heated bed, printer rez, easy to use, how much you need to use it.
greybeard
I recently recommended a Monoprice to someone who has difficulty learning and solving problems.
I did a lot of research (using my 5 yrs of 3D printing experience of 3 printers, including building two from kits and hacking them).
There are some good youtube vids on the Monoprice.
Amazon link:
https://www.amazon.com/Monoprice-Select ... 3d+printer
Of course, you may have skills that beg to build/hack something... or buy something robust yet fairly simple... Just recognize that at some point, regardless of the machine, something will need attention and ability to use some tools...
3D Print Parts
SWCNT
What do you want to do with the printer? That answer will help us in making suggestions.
Very subjective question but you have to start narrowing down somewhere!
The Prusa MK2s and the MK3 are good with very active support. Either in kit form or assembled.
The Flashforge Creator Pro and the QIDI Tech-1 and X-Pro are good solid machines.
A little smaller in size and cost is the QIDI X-one2.
A good single extruder machine with a larger volume and is enclosed is the QIDI X-Plus. I am testing this one and it has been a good performer.
arhi
"best" is very very very very subjective ... many good printers @ that price .. I'm currently testing craftbot2, 3 and XL and they are freaking awesome.... great build quality, awesome support team .. active community.. not as active community as for prusa for e.g... EU made, not PRC, so good QA, quality parts...
Embed M117 codes into G-Code
open source and unlicence
