krosnyak
4.1 improvements fail.
"•New Prime Pillar and Ooze Shield construction provides better stability, improved bonding between layers, and reduced material contamination
•Improved priming sequences ensure that a tool is always primed at the beginning of each layer during multi-extrusion prints"
My problem is that here is no retraction when the extruder leaves the part and moves to the prime tower.
See the pic below, all the strings co from the part to the rear left corner for each color on the priming tower, held the extruder shaft to confirm.
download/file.php?mode=view&id=7640
S3D-Alex
Re: 4.1 improvements fail.
Can you please post a Factory File for this?
krosnyak
"file is too large" error lol.
Use dropbox or similar.
H.
