AndersE
Hangs in mid print with smoothieware/board.
i have a delta that runs smoothie, and i sometimes in 4.1.1 it stops printing. Using the "force next" works, but it will blob if i am not at the printer.
Have never happened before on earlier releases.
No error in communication window is reported.
rrdavis
Re: Hangs in mid print with smoothieware/board.
If you print the same gcode file a second time, does it hang in the same place? Can you attach the gcode file?
AndersE
yes, it stops at the same place every time. I attach factoryfile.
It stops at the bottomleft cutout on the perimeters when laying the first layer..
This is not the one i complained about, but another i just found out.
I have checked the part with netfabb basic and it report no errors.
base2+3+4.factory
(42.77 KiB) Downloaded 448 times
AndersE
I have been printing some more now, and it soes not matter what i print. There is this hang (continue possible) in the beginning of all prints.
I have NOT changed anything on my computer, no updated firmwares or changes to configs for the smoothieboard.
Every single print it happens. No errors in the log at all.
DarthRevan
I remember reading previously that smoothie had problems with densely packed movement commands. Do you have firmware updates available? There seem to be a high number of retractions on your first layer. Have you tried changing your advanced retraction settings to see if that makes a difference?
