I can't seem to get filament to extrude at the start of a print for several cm.
Anything that S3D generates before the actual model prints is fine, but when I go from start code to S3D code, I miss several cm of plastic.
I've tried various start gcode files. Some lay a line across the front of the plate. Others extrude some material off the side then go straight to the print. Regarless, when that is finished and the tool moves to the print start, it misses several cm of material before extruding. If the first thing to print is a raft then I miss a few cm of raft. If it's a skirt I miss a few cm of skirt. If it's the model itself I miss a few cm of model.
I've been working around this by simply always printing a 1 ring skirt and ignoring the few cm of skirt at the start that don't print. I'm trying to do dual prints now though and since both extruders don't print a skirt the extruder that didn't print ends up missing the material when it starts to print something important. Then I get off to a bad start right away.
Any suggestions?
