Is a 90% First Layer Pointless Now?
It setting the first layer height at 90% kind of pointless now since the extrusion multiplier no longer stays at 100% of the set value when below a first layer height of 100?
It used to be that for a first layer height below 100% the extrusion multiplier would stay at the set value essentially causing a slight over extrusion for the first layer. My understanding is it no longer works this way.
Re: Is a 90% First Layer Pointless Now?
You're correct it no longer works that way. 90% first layer height will print the correctly scaled amount of filament for a 90% first layer height. If you wish to use the formerly popular "squish" method you can set to 100% first layer height and use the global G-Code offsets settings in the G-code tab to lower the entire build by an absolute amount.
It really boggles the mind why you took yet another item that worked fine and complicated the whole thing.
So instead of just setting it a 90% and leaving it for most all prints I now have to jump to another tab and calculate how much to lower the Z offset based on my layer height and do this for every print that has a layer height change from the last print.
Wasted time and effort.
airscapes
Sounds like a developer that doesn't use a 3d printer looked at that as a bug..
Yea, and at the rate they are going they will put themselves right out of business.
Too much competition now that is free.
It was mentioned in the changing log of V 4.0 or 4.1.
Before user have grumbled about it because they haven't understood why it is the best solution and now others are grumbling about the changes. But sure, there is someone who doesn't know what he is doing. That is the difference between practice and design.
To use the former solution someone must know that it is possible to reduce the layer height below the 100% (of general layer height) but holding automatically the extrusion amount to 100%.
The new solution I find more intuitive for beginners. Also other slicers they are coming from, don't know such a solution and beginners don't looked for it. So they merge 2 functions together without knowing why the result is bad.
GER
PS.: to the S3D-team
It is urgently necessary to refresh KEYBOARD WARRIORS TIP OF DAYS !!!
I am also quite puzzled as to why this change has been made. Why make changes that upset the existing and correct slicing behaviour of the software that give the overall impression that an upgrade has broken more things that it has mended!
It was exactly the same as the changes made to top layers. Top layers worked very nicely before an upgrade....and then a change is made that cocks many existing prints up. Why?
I would really appreciate that changes are only made that IMPROVE printing overall....and please always provide a reason for making changes...not just change the way the software works...and hope users like what you've done.
dkightley wrote: ↑Tue Mar 26, 2019 7:29 pm ...
Why make changes that upset the existing and correct slicing behaviour ...
... and it would be so easy to change it better, when the user has a drop-down menue where he can choose all values he needs.
All automatical solutions, depending of unknown situations (i.e. distance heatbed to nozzle) are pure luck but better than nothing.
To cancel this function was not great. Using instead the - negative - Z-Offset needs a intimate knowledge.
What S3D is saying?
We're hiring!
by Simplify3D
Realize it
H.
PS: the new CURA version 4.0 was coming out!
Ayres3D
I didn't realise this had changed either. That does seem like a backward step to me too.
SteveYYC
Thanks all for pointing this out and enumerating how the new version changes the first-layer/bed-layer.
Since I really don't like messing with global offsets, I added the following post-processing instructions to my S3D process instead to use the GCode M221 instruction to alter the extrusion factor for layer 1. Posting here in case it helps someone else.
{REPLACE "; layer 1," "M221 S135\n; layer 1,"} ; use f/w to overextrude layer 1 @ 135%
{REPLACE "; layer 2," "M221 S100\n; layer 2,"} ; reset f/w extrusion to 100% for layers 2-n
