grplr
Craftbot 3 starts grinding and tries to leave build area
Tue Mar 26, 2019 10:41 am
Running a Craftbot 3. It has a feature called the Supervisor that monitors for filament jams. Yesterday I had the feature detect a jam and it couldn't clear it, so the print stopped. When I came home and checked, everything seemed good so I hit resume on the print, and the printer proceeded to be start the print over but it was offset by a few inches, and the printer started grinding and "bottomed" out in the y axis when trying to print, making some gnarly grinding noises.
It seemed as though the print didn't want to restart in the appropriate spot.
DarthRevan
Re: Craftbot 3 starts grinding and tries to leave build area
Tue Mar 26, 2019 1:28 pm
Sounds like a firmware issue if after a firmware initiated pause the print begins again with the wrong offset. Have you reached out to the manufacturer for tips about offsets and firmware initiated pauses?
grplr
Thu Mar 28, 2019 4:46 pm
No, I didn't reach out. I was sort of under the impression that S3D would have had some of this sorted out since the Craftbot 3 is listed as a supported printer. I have no issue reaching out but I feel I am not educated enough yet on this software since I have been relying on Craftware up to this point.
