Donovanjp33
Where do you define infill Extruder
I'm running a Qidi X-Pro, dual extruder. I want the walls and infill of an object printed with the left extruder. When it pauses to switch, The hot tool sitting on my print burns it. Where do you set infill extruder? I have tried every setting I can find, most recently I set the auto-config "left only" profile. When I ran this print it didn't heat the right extruder, but still tried to print infill with it, stripping my filament.
S3D-Alex
Re: Where do you define infill Extruder
You define the Infill Extruder in the Infill tab of the Process Settings. This drop-down is found in the "General" section.
That being said I would recommend reloading the stock profile for this machine as our Auto-Configure is not set up by default to use a different extruder for the part and infill. This can be done by going to Help > Configuration Assistant and selecting the Qidi Technology X-Pro from the menu.
