sstephan
[BUG] thin sheets disappears
Mon Apr 15, 2019 2:15 am
i print thin sheets for fine bed leveling and occasionally as a build plate for "hard to stick" materials .
i noticed that in viewer when the part is too thin it will occasionally disappear .
in the image its the same part (0.15mm thick 150mm square sheet) from different angles . it seems that overhead it appear normal then when you move from there it goes disappearing .
print preview looks normal .
