oakmeadows
Windows 10 update causes simplify 3d to stop working
Hello i hope some one can help me please everytime windows 10 does an update on my pc i can never start simplify 3d again untill i uninstall it and reinstall it again can any one shed any light on it please .I dont have any viruses and i run my virus scanner every other day
many thanks
kevin
cbarry
Re: Windows 10 update causes simplify 3d to stop working
That's weird, and not at all normal.
So I understand:
* windows update runs (does it reboot?)
* you try to start S3D and it will not respond, not do anything? No error messages?
* you are using the latest version of S3D, correct?
If it does not reboot itself, do you reboot before trying to run S3D?
It almost sounds like the infamous DLL Hell situation, where a required shared library keeps getting overwritten. Make sure you are indeed running the latest S3D code available, and have a look in the WIndows Event Log for clues.
Why not take a read through some of the results of this search: search.php?st=0&sk=t&sd=d&sr=posts&keyw ... e&start=20
I'm sure its worth trying some of the suggestions made when this issue has happened previously.....
