rendez2k
Vase Mode Issue or Normal?
Sun Jul 28, 2019 2:18 pm
Hi all, I've tried vase mode twice now. I've just stopped my second print as it seems to be starting off the same as the first, where the bottom is weak and stingy and the outer walls are almost in two layers. Is this normal? Should I let it continue?
Re: Vase Mode Issue or Normal?
Mon Jul 29, 2019 2:19 pm
The image in your post is no showing...….but do take a read of this thread. It may help answer at least one of your questions:
viewtopic.php?f=9&t=13442&p=51350&hilit=vase#p51350
rendez2k
Tue Jul 30, 2019 5:25 am
Thanks! That makes a lot of sense now. However, turning on 'merge all outlines' gives me a solid top on the model in the preview, will it print that way?
Tue Jul 30, 2019 9:52 am
It will, yes. To stop the top layers printing, simply set Top Solid Layers to zero.
