Post your settings here. I'll post mine up after this print finishes. Toying with 4000mm/min. I had it at 5000 but some small objects come out with details smeared. The extruder just isn't good enough. I'm cutting the time down by 80% for most prints vs the stock xyz software.
I'm using red and black filament in case it matters. The white printed really badly, good thing it only came with 300g.
Fast print: 0.2mm layer, 5000mm/min on 0.4mm extrusion width
Medium print: 0.2mm layer, 4000mm/min on 0.3mm width
Fine print: Haven't configured it. I use this for rapid prototyping, I can't wait 8 hours for a 100% perfect object when I can print an acceptable one in 80 minutes
