Exerqtor
Disable auto generated start script
So like many others have pointed out the part cooling fan starts automaticly on the first layer even though the fan speed is set to 0 for the first 4 or what ever layers if the "Increase fan speed for layers below" is enabled.
To avoid this, and the input of other random unwanted "junk" gcodes getting fed in before our custom start scripts couldn't it just be an Disable/enable automatic start script generation button inside the Scripts->Starting Script tab?
Re: Disable auto generated start script
You can disable this setting's effect on your first few layers by quickly creating another process with the variable settings wizard. Turning off this advanced fan setting in the process for the first few layers will disable the automatically generated fan speeds.
