Carlbosson
user defined macros
How do you set the "User defined Macros" on the machine control page? I would like to set one the drop the Z by 50mm then center the nozzle. In this case x=150mm and Y=150mm.
I would like to set another to enter the M916 command to start after a power loss.
Thank you in advance for all your help.
Carl
S3D-Chris
Re: user defined macros
You can set the macros by going to tools > firmware configuration > macros tab
Carlbosson
Thank you
S3D-Chris
Hairig wrote: Is that all the macros functionality there is, Chris? Or are there some hidden functionality too?
The Macros tab contains everything we have currently. If you have ideas for additional options you would like to see please let us know by submitting a feature request!
