xboxhacker
F/W Retraction Min Travel not working
Recently upgraded from Smoothie to Duet WIFI. So far everything is great!
I want to use Firmware retraction (as suggested by Duet). It seems to work fine. I dialed the speeds and feeds in to almost zero stringing.
But it retracts for EVERYTHING. Every shell, every brim....all the time. I have the min travel set to 2mm and the "only retract when crossing open area" to on. But it does not seem to do anything.
Do these setting not work with F/W retraction?
My setup:
Delta printer
Duet wifi ver 2.04
Post Prossessing: (m101-3 set to on)
{REPLACE "M101" "G11"}
{REPLACE "M103" "G10"}
{STRIP "M102"}
TIA!
