davorin
Start of outline/infill in same corner
Good afternoon (o;
Is there a way to have the infill being started at the same corner as the outline on the first layer?
When I swap the +45/-45 angles in the infill section the infill starts always in the same corner:
Re: Start of outline/infill in same corner
The align start points function of the layer tab currently only aligns the outer start points for your perimeters. I'll submit this feature request for you to be able to do the same for infill start points and keep an eye on your thread to gauge other user interest.
davorin
Good evening (o;
That would be terrific if S3D could someday do that :-)
From time to time I experienced on the first layer that the outline was printed fine...but when starting the infill it took a short time to print the infill due to the retraction and movement....the larger the object the more the effect was visible....
thanks in advance
richard
PS: Looking forward to 5.1 then (o;
XoTT@6bI4
why don’t you want to take part in alpha testing of versions 5.0.0 - 5.0.3?
davorin
Hello
Would love to :-)
Where can I subscribe?
Never got any invitation before....
cheers
richard
davorin
Well..seems there is no alpha testing available for existing customers (o;
XoTT@6bI4
davorin wrote: ↑Mon Feb 17, 2020 4:35 pm PS: Looking forward to 5.1 then (o;
There was a misunderstanding. You specified version 5.1, skipping 5.0.
  It is not necessary to register with testers. The developers promise to release version 5.0.0 soon (it may work out as with 4.1.0), but you need to buy a license. viewtopic.php?f=8&t=14166
