alphaCentaur
Object Disappears after Prepare to Print (only supports are visible)
Hello all,
After I press "Prepare to Print!", the object disappears (only the supports are visible).
A lot of threads have discussed this issue but I am not able to find a solution.
So I have posted my factory file. I would appreciate if anyone could help.
Thanks
splitter_FF_for_analysis.factory
(354.86 KiB) Downloaded 339 times
Re: Object Disappears after Prepare to Print (only supports are visible)
Y-piece slices okay on my PC. I think you need to look at your hardware...…
Hopefully, someone may be able to suggest what you now need to do.
S3D-Alex
Could you contact us at [email protected] so we can look into this a bit further?
Daniel
if you are using 4.1.2 version , you need to log in your sofware
older version work well without log in
