Sparky
Filament Extrusion/Retraction Method
I haven't found dedicated filament extrusion/retraction buttons, so what would be the procedure?
Simplify3D
Site Admin
Re: Filament Extrusion/Retraction Method
If you bring up the Machine Control Panel (Ctrl-P or Command-P on a Mac), you can select the Extruder axis. In particular for the extruder, I would suggest using the "Custom Jog" button to move a specified distance. For example select Extruder axis and enter 225mm/min for the speed. Then enter 20mm in the custom jog box and press the button to extrude 20mm of plastic. You could enter -20mm for retraction.
Does that help?
ketil
I also struggled to find that.
If you're sticking with the "select axis then move" concept, perhaps you could add shortcuts like hitting x, y, z and e to choose the axis, and add a plus and minus button for the custom distance?
Simplify3D
Site Admin
Nice, I like that idea! Especially useful for the extruder. Saves you from having to enter a minus sign every time you want to back up.
Sparky
Simplify3D wrote: . . . Does that help?
Yep, and it works nicely, but leaves me questioning my observation skills and wondering how I've avoided snakebites for so many years.
