symonty
Support for CR-6 SE
Since this is a standard Creality type printer, is the CR-6 SE supported.
Can I just adjust the standard profile to suit the speed and retraction settings and all should be good?
S3D-Chris
Re: Support for CR-6 SE
Our support team can help you set up a profile for the CR-6 SE.
tobyCwood
How about posting the settings for all of us rather then pushing the poster to one on one support!
FWIW everything is the same as the Ender3 except for the bed size. Z height is the same, X & Y are 235mm.
Thanos2001
Best way to modify the size after selecting Ender 3 as the printer on a CR-6 SE?
Thanos2001
Found this
G28 ; home all axes
G29; I like to do an ABL on every print
ending gcode:
M104 S0 ; turn off extruder (set temp to 0)
M140 S0 ; turn off bed (set temp to 0)
M84 ; disable motors
G28 X0 Y0
Is there a way to set this as a default?
Thanos2001 wrote: Sun Sep 27, 2020 9:35 pm Found this
G28 ; home all axes
ending gcode:
G28 X0 Y0
I'd still recommend just emailing support. They're quick to respond and already have a profile for this machine.
however, if you wish to start with the Creality Ender 3 profile and make edits to the starting and ending scripts the post linked below is really helpful in walking you through editing the various scripts in the scripts tab of your process settings.
viewtopic.php?t=1959#p7574
Zand3rs-Forum
Did anyone get help from support and maybe can help me as well?
PeterE
I would like to hear the same. ;)
Andresia
I would also like a profile for this printer. I emailed support and it's been a few days and I still haven't heard anything :(
Mordorf
This is the profile I'm using and is giving me excellent prints.
Creality_CR-6_SE.fff
(11.85 KiB) Downloaded 1317 times
