nickfysiek
starting script bltouch
hi i am wondering if anyone could share their srarting script. if i am using my bltouch now the nozzle givea to much ooze and when it starts printing it getst stuck.
i would prefer
bed heating to 60
a leveling
home x and y
heat extruder
extrude some fiament
start print
thanks a lot
beazleybub
Re: starting script bltouch
I am having the same issue.
PicoTreed
this is an example for RepRapFirmware, please go reading about GCode in order tailor the script on your needs.
Consider that just after G29 you can insert the commands to bring the nozze in the park/heating/purge area, while after G92 E0 you can insert commands to do some works before start printig (ex. clean the nozzle on the brush.)
T1
M561
M376 H0
G28
M557 X(value):(value) Y(value):(value) Pn:n
G29
G1 F[travel_speed] Z15
M109 S[extruder1_temperature] T1
G92 E0
R&D for 3D printers, materials & software.
