bhedrick
[ADDED] Please add a profile for the Flsun Super Racer
I see there is good support coverage for Flsun.
FLSUN Cube
FLSUN i3
FLSUN i3 Plus
FLSUN Kossel Delta
FLSUN QQ Delta
Could you please add the Super Racer (SR)
https://www.flsun3d.com/product/3.html
DoctorRudd
Re: Please add a profile for the Flsun Super Racer
Why not just use the Q5 profile and adjust the print size?
bhedrick
Is that the only difference, build volume?
neilr
Took some doing, but I did manage to get S3D running well with FLSun Super Racer. The biggest issue had to do with the filament runout sensor not working. It did work however with gcode from Cura. I went back to Cura briefly and discovered two things: Cura inserts an M82 (absolute E) at the start of the gcode, and does not zero out the extruder distance (G92E0) during the run. I was able to make Simplify3D mimic this behavior, and now the runout sensor works normally.
I am attaching my FFF file, it's set up for quick PLA printing.
Neil
FLSUN SR.fff
(11.75 KiB) Downloaded 640 times
Happy to say the FLSUN Super Racer is now present in the V5 configuration assistant. Just go to Help > Configuration Assistant and type the printer name. We did a lot of testing with this machine ourselves so the profile was performing quite well. Thanks for the request!
