yesbird
Contact: Website Facebook
Replace filament is not working
Normally I used command
{REPLACE "; layer7" "M600\n; layer 7"}
without a problems, but found the case when it is not working.
Factory file attached:
test_abs_sbs.factory
(63.05 KiB) Downloaded 160 times
Have no idea what is the reason.
parallyze
Re: Replace filament is not working
yesbird wrote: ↑Sat Jun 11, 2022 7:23 am
"layer7" != "layer 7"
The space between "layer" and "7" is missing.
yesbird
Thanks, I have missed it !
