james891
Printer Print Files Selection Order
Hey guys,
Not sure if this has anything to do with simplify 3d, but both printers I use it on, when I export to SD, show my latest created files last on the list when I select to print. They used to show first but at some point they went in another order. Is this a setting in Simplify 3d that I could select to make those files come first?
Re: Printer Print Files Selection Order
If you're selecting which file to print from a menu on the printer that is likely being controlled by the printer's firmware. Perhaps you have installed a firmware update on your printers recently that brought about this change? I, personally, like to only keep one print file on my SD card at a time. This way I never accidentally select the wrong one when I goto start my print! :D
