OnlineSjoppen
ultimaker2 change filament
Hello
How can I tell simplify that I want to change the filament at a certain height
M.v.g. André
KeyboardWarrior
Re: ultimaker2 change filament
You can save the G-Code file, then open the .GCode file up with a text editor and where you want to pause add a new line that just has
"M0"
Then save the file, go to the Machine Control Panel, hold Shift+click Print, then select the modified G-Code file. When that M0 is read, it will show a prompt on your screen in Simplify3D to click the resume button, otherwise you can manually jog everything around and change filaments, etc.
OnlineSjoppen
Hello
In order for the code and the code additional information such as an offset remain fresh and clean the extrude.
And where can I find the Gcode comando to use?
M.v.g. André
KeyboardWarrior wrote:You can save the G-Code file, then open the .GCode file up with a text editor and where you want to pause add a new line that just has
"M0"
