anthonype
[FIXED] Full Crash When Cancelling Variable Settings Wizard
System: 2018 MacBook Pro
OS: MacOS Ventura 13.0.1
Description:
- When trying to use the variable settings wizard, if you try to back out or cancel the wizard, Simplify3D crashes without warning.
Steps To Reproduce:
1. Launch Simplify3D V5.0.0
2. In The Top Toolbar Open Tools -> Variable Settings Wizard...
3. Click Cancel
4. Notice The Software Completely Shuts Down
* This also happens when click the 'X' button to close the pop-up window
Re: Full Crash When Cancelling Variable Settings Wizard
Oddly enough, I'm not able to get this same crash to happen when following those steps on a few Macs in our office. Do you think it has to do with any particular process or model you have loaded?
bolsoncerrado
I couldnt reproduce this on an iMac with BigSur, if it helps troubleshoot.
Also do you have any hi-poly model loaded when this happens? Or is it manifold? DId you try with a BLANK NEW project?
bolsoncerrado
I was able to reproduce this on my new freshly installed Mac M1 with Ventura too.
With BigSur this wasn't happening!!
No model needed to be loaded for it to happen.
How weird!!
This was fixed in our latest Version 5.0.1 release. Please update to that version and the problem should go away.
