gelly
Is it possible to print the raft with a particular extruder
I am trying to pro a dual extruder print. How do i choose what extruder to use for the raft ? will it use the primary extruder only ? can it be changed ?
RobH2
Re: Is it possible to print the raft with a particular extru
Here is a very handy link. It helped me with the same issue. If you still have questions after carefully reading this, write back.
http://www.simplify3d.com/support/tutor ... extruders/
Makerfarm Prusa i3 8". JHead .5mm / Magma Head .4mm / Wade's Extruder
gelly
thanks, yeah, i followed those instructions, you can choose the material for the support. But the Raft per se is always by default assigned to the primary extruder, which i need to change to the second extruder. My issue is that PVA doesn't stick into PLA. So i want the raft in PVA. Is it possible to specify the raft to be done by the secondary extruder ?
gelly
Just saw that, excellent!! will try it out tomorrow
