I am printing a model where I'd like to use concentric infill on the top (visible) surfaces, but avoid it on the bottom layers. Basically, since concentric infill follows the same pattern on every layer when building a on a flat surface, it is weaker than the rectilinear infill (which criss-crosses).
What I am doing is setting up two processes, and then in the advanced options setting one process (with rectilinear infill) to stop printing at 1mm, and then another process (with concentric infill) to start at 1mm.
Is this the best/right way of doing it? Preview looks fine.
