S3D-Jason wrote: ↑Mon Jan 16, 2023 10:32 am
Nothing changed with the V4 server or software, so if that is also acting slow that certainly suggests something else external is causing the slowdown. You said you have a complex network at home - we have definitely seen other customers with complex networks where that was the cause of the slow startup behavior. What about trying to connect your computer to an entirely different network that does not have all of that complexity to see if it opens faster?
I connected my computer directly to the router, got public IP on my windows (very unsecure
) - same issue
I connected my computer using mobile network, super simple setup, modem, nat, my computer - same issue
it does not happen "non stop" but I just measured,
starting 4.1.2 - 57 seconds
closed it
starting again: 55 seconds
closed
during startup it was using 0% cpu and 26MB ram
starting 5.0 - done in 7 seconds
closed
starting again - done 2 seconds
closed (downloading 5.0.1)
starting 4.1.2: 55 seconds
closed it
so for e.g. this morning 4.1.2 takes ~minute to start and 5.0 is up in few seconds, yesterday both took over a minute to start, day before 4.1.2 was instant and 5.0 took minuts to start ..
dunno when this started, I did not start 4.1.2 for more than a year, was started after year+ when 5.0 arrived
Embed M117 codes into G-Code
open source and unlicence
