bolsoncerrado
[FIXED] v5.0.2: Scale % NOT working/staying
Can't believe you didnt fix this YET.
VERY VERY frustrating!!
scubatron
Re: v5.0.2: Scale % NOT working/staying
This needs to be addressed, scaling stays at 100% and does not change no matter how much the object is changed.
Rotation also stays at 0 degrees...
stormtrooperguy
Seconding this. I really like being able to look back at saved factory files to see what scale % I used. Not having that available is a big problem.
RetroDesign3D
I dont think they care.. this has been brought up so many times with no comment from S3D team at all.
scubatron
Also the uniform scale resets to being clicked anytime you make a scaling change.
This need to keep being bumped to the top till they respond!
bolsoncerrado
Yeah lets keep it up in the list so new potential customers realize the crap they're buying! Good idea!
scubatron
It's just so odd to ignore it completely when it seems like such a important feature. Its sad when we know they read these posts and just drop the ball on simply acknowledging it needs to be fixed.
bolsoncerrado
In fact some similar issue happens as well with the rotation percentages so i guess its all about the new redesined UI they created... :(
scubatron
Should we just get a summary of all the issues with the UI in respects to rotation and scaling?
scubatron
Ive also come to find the preview to show a single line at a time instead of a layer also doesn't work correctly and just shows the starting points. S3D Jason please do your job and answer your customers!
