ChoreBoy
Version 5 puts M107 command on first line of .bfb file - how to prevent that from happening
I recently upgraded from version 4 to 5. When I create a bfb file using version 5, there is an M107 command on the first line of the file. Unfortunately that command messes up my printer so I need to manually remove it from the file each time. How can I get version 5 to stop inserting the M107 command at the start of the file?
I have been using S3D version 4 right along and that does not put the M107 at the start of the bfb file. I made every effort to use the same profile settings with both versions.
Thanks
Re: Version 5 puts M107 command on first line of .bfb file - how to prevent that from happening
What BFB machine do you have? I looked at a few of our machines here, but they seemed to accept M107 okay. It looks like some of the V4 profiles even included M107 in the starting/ending scripts, so I think several of the BFB machines must support those commands.
