Kissable1089
Object Exclusion for use in klipper
Object Exclusion would be wonderful.
Attached is an STL that I made to produce a single extrusion cube that is one layer high for simplicity sake and the gcode generated by Orca that shows the object exclusion.
It would make a big difference for klipper users.
New Part (1).stl
(1.64 KiB) Downloaded 2450 times
New Part (1)_PLA_11s.gcode
(18.57 KiB) Downloaded 2424 times
EdStreet
Re: Object Exclusion for use in klipper
that would be superb if that could happen. right now you are limited to only one part at a time which is terrible.
ptegler
bummer...yep...just came looking to see if S3D supported exclusion statements. Apparently not :-( Seems it would be relatively easy to implement as the parameters of objects is know if/when you use skirts. If any xy coord fell within that range, it should be easy for S3D to add the proper commands that identify the object there, thus allowing bypass of that singular part like most other slicers do.
..well...we can all dream right?... how about as a post processor even. (maybe?...please?)
dmitryr
Contact: Twitter
+100
Marki
+1 for this request.fm whatsapp download
Kissable1089
An instance where i could have cancelled the test square and kept the rest
IhatemyISP
+1 for this
Michael_Jakob
Locking forward for this function to be added. Tried to do some postprocessing of the g-code but this did not work since there are no indicators for the objects. Here is a script used for some of the other slicers.
https://github.com/kageurufu/preprocess_cancellation
Most slicers support this feature natively today without needing the script.
Michael_Jakob
I made an update to the g-code preprocessor and it can now be used in combination with Simplify3D with some extra preparation during print: https://github.com/kageurufu/preprocess ... on/pull/33
sudosmudo
Would’ve been nice if this could be added asap as it was requested +3 Years ago and shouldn’t be that much of a hassle
