brian444
wont stay open
Windows shut down improperly while s3d 5.1 was open in background, now opens briefly and then shuts down. Reinstalled, same issue. I know in previous version going to C:\Users\brian\AppData\Local\Simplify3D\S3D-Software\savedState and deleting these files worked but not in newest version., Any advises? Thx.
brian444
Re: wont stay open
Update, going to C:\Users\brian\AppData\Local\Simplify3D\S3D-Software-V5 and deleting .gcode files does work!
Wolfie708
Re: wont stay open
Mine is doing exactly the same.
Both 5.10 and 5.11 start up with typical screen, then after a second or so, blue 'working' wheel appears adjacent to mouse pointer then it crashes and closes.
I've tried an uninstall to no avail.
Version 4 still works fine.
Re: wont stay open
You could try following the instructions here to remove any leftover files or settings:
https://www.simplify3d.com/resources/faq/#quest-6350
Many of the things like gcode files and printer profiles are stored in the file system in those folders, so you can copy them to a different location if you want a backup before you try deleting the folder.
Rolfchen
Re: wont stay open
It's similar for me.
I can log off Simplify via the interface.
Under License Management it also says "not activated".
But then I can not log in again under Linux.
All attempts that were suggested fail.
The program does not start and the login window does not open.
Meanwhile I am sorry that I spent money for the extension to 5.0.
I am now using Cura again.
Re: wont stay open
If you're having trouble with your license, you will need to contact our team directly at the link below:
They will be able to lookup more details about your account to help resolve the issue.
