AndersE
Extrudertemp whacko.
Since the new update i have been having problems with extrudertemp at startup of print.
Sometimes it just shoots to the roof (300c) .. and it starts to smoke a lot ;)
I have jerked the wires to the thermistor but there does not seem to be any problem.
And when i get it to start printing there is no problem the print through.
I just happens sometimes when pressing "begin print"
Manual setting always work.
Or could it be that the thermistor is about to give up?
Re: Extrudertemp whacko.
Sounds like a hardware or electronics issue.
Just go be sure, open up your gcode files in a text editor. Unless you see a command like "M104 S300" then it isn't the software's fault.
