Phgeis
One build process multiple model with different settings
H imy idea would be to build within one process four similar bodies next to each other but with different processes ( i.e. different multipliers or with different retracts or coast settings.
How do I do that tried but dont manage to assign on process to one model and another process to the other one.
Simplify3D
Site Admin
Re: One build process multiple model with different settings
I believe what you are looking for is the "Select Models" button in the bottom left of your FFF Settings dialog. That will let you choose what models a specific process applies to.
Phgeis
Okay found it and managed to create the gcode. But it did not output any x3g file.
Imported the gcode to repg and than created file: did not work!
is it possible to get an x3g out of multiple processing?
0.5cyl x4.gcode
(379.57 KiB) Downloaded 387 times
